so i went to go fold today and it was taking for ever on my gpu so i opened gpu tweak and found my gpu (gtx 970) would not go over 540 mhz core clock no matter what i do, any advice ?
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
https://linustechtips.com/topic/439984-gpu-problems/
i even tried to apply my oc of 1470 and still nothing
and a car thread !
https://linustechtips.com/topic/439984-gpu-problems/#findComment-5898441
try running a stress test such as 3dmark
Ya I was going to try it on some games and such but I don't have time right now, I have some stuff to do, I was just gonna turn it on and let it fold for the day while I was gone but now that happened
and a car thread !
https://linustechtips.com/topic/439984-gpu-problems/#findComment-5898542
Are you using the EVGA Precision X OC tool? If you make it go Kboost and it's not stable at the load FAH puts on it, it will default to this frequency for no reason. Just happened to me when I tried applying an OC profile (which is otherwise stable), and it not only RESET my WUs for GPU, but it derped out on me and went from 1.2GHz to 540MHz.
This is the Craft of PC Building. Mastered. #AshlarPC
https://linustechtips.com/topic/439984-gpu-problems/#findComment-5898629
not using precision I'm using gpu tweak as stated in the first post
and a car thread !
https://linustechtips.com/topic/439984-gpu-problems/#findComment-5898923
Might I assume all OC tweak tools use a similar function that causes this phenomenon... Are there any circuit engineers in the house that might be able to explain this? (I am "me too"-ing this issue) Would love to have an explanation as well.
https://linustechtips.com/topic/439984-gpu-problems/#findComment-5898956
But the thing is that it's not even running an oc it's just the stock clocks and I usually run it over clicked but I didn't want it running hot today so I left it stock :/
and a car thread !
https://linustechtips.com/topic/439984-gpu-problems/#findComment-5899214
just ran unigen valley and same story, maxes out at 540, maybe i should go ask in the gpu section since now i know its a all around issue
and a car thread !
https://linustechtips.com/topic/439984-gpu-problems/#findComment-5899315
