So I have no idea if this is the right place to post this, my first time using this forum & forum post.
Anyway I'm planning my build and literally starting from the chassis up & I was wondering if anyone here is from EU/UK that knows anywhere I can get these switches:
http://www.performance-pcs.com/vandal-resistant-illuminated-latching-switch-silver-22-19mm-blue-ring.html
http://www.performance-pcs.com/vandal-resistant-illuminated-momentary-switch-silver-22-19mm-blue-dot.html
The second question is I'm going with an x99 build and want the Rampage V Extreme board, does anyone know if the HD and LED outputs are 12v or less? I can't find it online anywhere and Asus haven't got back to me either.
Third question, does anyone know if you can get these radiators in Europe/UK
http://www.performance-pcs.com/black-ice-nemesis-360gts-ultra-stealth-u-flow-low-profile-radiator-white.html#Specifications
Any help/advice would be much appreciated as this is going to be my first ever custom case and hopefully the last one I'll ever need to build.
https://linustechtips.com/topic/439873-first-custom-case-build/
Contact Performance PC and see if they can ship to EU
Adobe Photoshop Graphic Artist and PC Building Enthusiast
Corsair 750D | I7 4770 | Aorus Waterblocked 1080ti | z97A Gaming 7 MSI | EVGA supernova 750 G2 Gold | 900P 280Gb 256GB 850PRO 128 GB 850 EVO| 32GB Corsair Vengeance (4x8GB) | Logitech g502 mouse | Corsair K70 Cherry-MX Brown | Full Custom Water Cooling Loop |
https://linustechtips.com/topic/439873-first-custom-case-build/#findComment-5897127
Those switches are actually made by a UK company called Bulgin. They have a list of distributors on their site: http://www.bulgin.co.uk/HTMLDocs/Distrib_main.php
I can't find anywhere that sells those rads in the UK.
EDIT: There's also re-brands or very similar designed switches available on OCUK https://www.overclockers.co.uk/search_results.php?keywords=vandal&_=1440858433927
@KeyVahn make sure you follow your posts (top right of the page) so you get notifications when people reply.
https://linustechtips.com/topic/439873-first-custom-case-build/#findComment-5897164
Oh wow you guys responded so fast, thanks for pointing out the follow thing! I've done that now.
Cool Bulgin sell via RS in the UK didn't know that - dealt with RS before! thanks for the link @Oshino Shinobu
Thanks Evolved_Evil I hadn't thought about asking if they shipped to EU/UK - just assumed they likely wouldn't.
https://linustechtips.com/topic/439873-first-custom-case-build/#findComment-5897331
