Hi guys,
My coworker would like a decent headset for $40 or less with a microphone for skype calls.
What is the best $/quality ratio headset in that price bracket ($0-$40)?
Thanks,
Vitalius
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/43984-best-headset-for-40/
Plantronic 380
Very good for the price.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/43984-best-headset-for-40/#findComment-575956
Plantronic 380
Thanks, but I'm talking US $40. Those are $45 without shipping or taxes.
https://linustechtips.com/topic/43984-best-headset-for-40/#findComment-575964
Amazon.com - http://www.amazon.com/dp/B006ZS5AQA $35
I have a pair of these, the mic quality is excellent, and the sound is not that bad either, also very comfortable.
Could also go for the Creative HS800 Fatality.
https://linustechtips.com/topic/43984-best-headset-for-40/#findComment-576002
Creative Draco HS-850, using one myself and they're absolutely beast for the price. Bought it at SGD40 (~USD32) when it was on sale at an IT fair, but since Creative is a local company of Singapore i'm not sure if shipping would kill it for you.
https://linustechtips.com/topic/43984-best-headset-for-40/#findComment-576014
Why I only checked one place, I will never know. Thank you.
Awesome headset, however they are about $50-$80 depending where you look.
So $40 after taxes and shipping?
Yes, preferably. Cheaper is better.
https://linustechtips.com/topic/43984-best-headset-for-40/#findComment-576024
Well  i have no clue how these sound, but i am sure they would do the trick for some Skype calls
http://us.ncix.com/products/?sku=81476&vpn=CA-9011118-NA&manufacture=Corsair&promoid=1300
https://linustechtips.com/topic/43984-best-headset-for-40/#findComment-576041
