Hey, basically I play CS:GO at a low resolution but my monitor is 4K. I need to keep it in Fullscreen Windowed, as I have many monitors. Here is where my problem starts; to change resolution, you have to put CS:GO into fullscreen which is a big no no. What I've been doing is changing the resolution manually in Windows, but I have to change it every time I launch CS:GO which is a pain.
TL:DR - How to keep CS:GO at a low resolution in Fullscreen-Windowed while keeping my monitor at a high res (or to find a way to quickly switch)
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/439748-csgo-resolution-help/
There has to be a launch setting command/s on steam that lets u do what u want.
I just don't knw which one.
Rig: I5-3570K@4.3Ghz - Cooler Thermaltake Frio Advanced - Ram Kingston 1333Mhz 8gb (2x4) - GPU GTX 970 4GD5T OC - Motherboard Z77MA-G45 - PSU CoolerMaster GX II 750w - Storage WD 500gb HDD - Sound Edifier M3700 5.1 - Headset Corsair Vengeance 1500 - Mouse Razer Deathadder 2013 - Keyboard Razer Anansi - Mousepad Steelseries QcK+ - Xbox 360 Wireless Controller x2
https://linustechtips.com/topic/439748-csgo-resolution-help/#findComment-5895590
Set your monitor to the same resolution as what you want to run in CS GO. Or don't want a smaller window. I believe you can do -h 1920 -w 1080 if you wanted to do 1080P, however I am unsure if thiis works in fullscreen windowed
My current build - Ever Changing.
Number 1 On LTT LGA 1150 CPU Cinebench R15
http://hwbot.org/users/TheGamingBarrel
https://linustechtips.com/topic/439748-csgo-resolution-help/#findComment-5895594
yea that's the problem, I don't want to do it everytime I launch csgo
https://linustechtips.com/topic/439748-csgo-resolution-help/#findComment-5895604
I believe you can do -h 1920 -w 1080 if you wanted to do 1080P, however I am unsure if this works in fullscreen windowed
https://linustechtips.com/topic/439748-csgo-resolution-help/#findComment-5895609
Did 3840x2160 and it did fill up my screen, but it sadly doesn't keep the 4:3 resolution :(
https://linustechtips.com/topic/439748-csgo-resolution-help/#findComment-5895619
Managed to force it to stay at the 4:3 resolution, but now it looks like this
https://linustechtips.com/topic/439748-csgo-resolution-help/#findComment-5895625
