Help on selecting a platform
Solved by Wired360,
The 5820k has 28 PCI-E Lanes while the 5930K has 40. Running 2 way SLI and a PCI-E SSD should be enough but if you want extra PCI-E Lanes for more bandwith, be my guest
I'll probably go with the 5930K if I find it on sale by then, incase I add any other pci-E accessory. I think this is a good and solid build.
Wow...
Invest on a custom cooled GTX 980 Ti. The Palit Jetstream edition are a step above the reference coolers.
I'll stick with the G1, especially the ever so slight lower thermals, and price being less
On another note, I'm coming from an IPS display and wanted to know if I should stick with IPS or go with a 144Hz monitor? I looked at the Dell U2515 and I think you can change the refresh rate to 75Hz... Any opinions?
