So I plan on buying the corsair 450d and equipping it with some thermaltake riing white LED fans. I also want to include some ambient case lighting by the window, and the obvious choice for RGB would be the corsair link, or so in my eyes. Do you guys have any better solutions for RGB case lighting?
Thanks,
Peter.
CPU: Core i7 4790k | Mobo: Asus Z97-P | RAM: Corsair DDR3 XMS3 8GB | GPU: Gainward GTX 970 4GB |Storage: 1TB Seagate Barracuda | PSU: Cooler Master BII-600 | Cooling: Corsair H110i GTX | Displays: 2x Dell U2414h | Kb: Corsair K70 RGB Cherry MX Brown | Mouse: Corsair Raptor M45 | Case: Corsair 450d Console: Xbox One Ext: DXRacer F-Series Red, Trust Tytan 2.1 Sub & Speakers, HyperX Cloud II, SCUF Infinity1 X1 Controller | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/439276-best-case-led-lighting/
Thanks,
Peter.
hell yeah. that stuff is expensive as hell. go pick up ebay or amazon 5050rgb leds. they run off 12 volt, so you can get a molex to barrel connector(what they use) for a few bucks. you can get 30 feet of lighting plus everything you need for sub 30-40$
in the us anyway*
https://linustechtips.com/topic/439276-best-case-led-lighting/#findComment-5889442
If you're looking for RGB lights, I'd recommend the NZXT Hue. That's if you have a front drive bay spare. All controlled through 3 knobs on the front. You can turn the brightness down too, so you can achieve the correct amount of 'ambience' you like.
EVE (My Gaming Build)
Motherboard: Asus Maximus VII Ranger - CPU: Intel i5 4690k @ Stock Speeds - Cooling: Phanteks TC-12DX - PSU: Corsair RM750 - GPU: MSI GTX 1070 - Storage: 1x 120gb Samsung 830 Evo SSD (OS Drive) | 1x 120gb Hyperx 3k SSD (Audio Editing) | 1x 480gb Sandisk Ultra II SSD (Games) | 1x 1TB Hard Drive (Mass Storage) - Case: NZXT Phantom 530 - Misc: NZXT Hue RGB LED and controller
https://linustechtips.com/topic/439276-best-case-led-lighting/#findComment-5889539
If possible I'd like not to use up drive bays to give my case a cleaner look, but it would mean I can control the exact colour of my lighting.. predicament.
https://linustechtips.com/topic/439276-best-case-led-lighting/#findComment-5891688
You can set RGB kits from say Modguru or Icemodz which use a controller type setup and all premade if you don't want to have to do more work with rolls of LED strips.
https://linustechtips.com/topic/439276-best-case-led-lighting/#findComment-5891774
they seem like good options, what length strip should I get to do bottom, side and top of the window in a 450d?
https://linustechtips.com/topic/439276-best-case-led-lighting/#findComment-5895437
Usually having LED strips on both the top and bottom are more than enough to illuminate the case, just be sure to not have a direct line of sight to the LED strips themselves and have them cast that light out to evenly light the components inside.
https://linustechtips.com/topic/439276-best-case-led-lighting/#findComment-5895457
so I would probably need two LED strips with an extension to run across the side just to do the top and bottom?
https://linustechtips.com/topic/439276-best-case-led-lighting/#findComment-5899455
Some kits come with an adapter or splitter you can separately purchase to run two or more LED strips or have a single longer strip tha you can say run along the top and down the side.
https://linustechtips.com/topic/439276-best-case-led-lighting/#findComment-5899662
Thanks,
Peter.
ice modz has some for a pretty decent price, I'm thinking of getting my stuff from there, here's a link http://www.icemodz.eu/store/#!/LEDs-Controllers-&-LED-Accessories/c/5346676/offset=0&sort=normal
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
https://linustechtips.com/topic/439276-best-case-led-lighting/#findComment-5900881
Thy come with wireless controller aND they have different modes and different options
and a car thread !
https://linustechtips.com/topic/439276-best-case-led-lighting/#findComment-5900893
I like software controll for my RGB LED, since that gives a lot more ways to create interesting effects.
Plus it allows for a total of 6,6 meters of LED strips split over 4 channels, which is more then enough for most cases.
I speak my mind, sorry if thats a problem.
https://linustechtips.com/topic/439276-best-case-led-lighting/#findComment-5922064
IMO the best result is gained from custom lighting with LED strips. Unfortunately there aren't many options that allow you to have software control over them.
Corsair Link is impossible to find these days (or or it seems), but there's the alternative of Corsair Commander Mini, but from what I hear the software is abysmal
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/439276-best-case-led-lighting/#findComment-5922286
I know you can but the corsair link lighting node directly from them
https://linustechtips.com/topic/439276-best-case-led-lighting/#findComment-5926212
That's some crazy expensive Solution in my country, 42 Euro just for that splitter with bluetooth.
as opposed to a 6  Euro remote controlled adapter.
i7-8700K @ 5.0 GHz 1.37v, EVGA GTX 1080 FTW Hybrid, Asus z370-A Prime
G.Skill Trident Z RGB 2x8GB 3200MHz CL16, Samsung 960 Evo 256GB, Samsung 850Pro 1TB, WD 3TB HDD
NZXT H440 White, Corsair H100i GTX v2, EVGA 750G2
Corsair AF140 x1, Corsair SP120 x2, Noctua Industrial 3000 RPM x3
https://linustechtips.com/topic/439276-best-case-led-lighting/#findComment-5939835
Its 30 Euro for the one with only usb, but yeah, its more expensive.
However, what you can do with it is also far more then a normal remote.
So its up to you whether or not the price is worth the extra functions.
https://linustechtips.com/topic/439276-best-case-led-lighting/#findComment-5940373
what are the extra functions?
https://linustechtips.com/topic/439276-best-case-led-lighting/#findComment-5941860
They explain it very well in the video, but its basicly: Software sensors (e. g. CPU load, network etc.), Control by sensor inputs (temp sensors), better controll over transitions/effects and better control over colors.
I dont belive a remote controller can do any of that.
https://linustechtips.com/topic/439276-best-case-led-lighting/#findComment-5942081
