BackTrack problem :(?
Solved by CornOnJacob,
Go to the settings for that VM > System > Processor > Enable PAE/NX. Check the box. As long as you are running a 32-bit OS in the VM, I think that should fix it (I had the same problem as you a while ago).
That being said, don't use Backtrack 5. The dev team for Backtrack made a new OS called Kali Linux, so switch to that. Backtrack/Kali is a very bad choice for everyday use. I would recommend Mint, or if you want an advanced setup that teaches you a lot, go for Arch.
