low upload obs stream help?
Solved by DEDRICK,
You can't do much with that bitrate. You don't want to exceed 80% of your upload speed because you need some for the game itself. When you saturate your upload your ping skyrockets.
In short, don't bother. Not even worth watching because it would look horrendous and your ping would make games unplayable. I'm not trying to piss in your cereal but it's completely unrealistic to stream in your current situation.
