I'd buy a 4L jug but I'd estimate you'd use in between 1 and a half to 2L. How big is your case?
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/43836-how-much-water/#findComment-573791
Corsair 900D, first time water cooling so I want to make sure I get enough coolant.
Yeah just buy a 4L jug of distilled. Or whatever coolant you're using.
https://linustechtips.com/topic/43836-how-much-water/#findComment-573810
Is there much temp difference between distilled water and a coolant solution.
A negligible difference.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/43836-how-much-water/#findComment-574805
