Hey LTT
My internet is being terrible. My dad and I have been doing some testing, and whenever my pc is off, he gets a ping of ~50ms. When my pc turns on, however, it jumps to ~1000ms and settles at 500 or 600. If I open Chrome, ~2000ms ping, if i open edge, 2200ms ping, and if I open firefox, 1400ms ping (all on my dad's PC). Note that these are WITHOUT opening any webpages.
If I turn my wireless off, then dad's ping goes back down to 50.
Done an anti-virus scan, disabled stuff in task manager, still happening.
Any insight would be helpful.
(BTW Australian internet)
If I've said something wrong, please correct me
My Builds:
Peripherals:
Keyboard: Roccat TKL Pro Cherry MX blue, Mouse: Roccat Kone XTD, Headset: Currently apple earbuds, planning to upgrade to hyperx cloud or hyperx cloud 2
Really Old Desktop
 Processor: Intel Core i7 920, Motherboard: Gigabyte GA-FX58-DS4, RAM: 9GB Corsair XM3 (3*3GB in triple channel) 600 or 800mhz, Graphics Card: Asus 8400GS passive, Asus GT630 4GB if i can get it working, Case: Cheapo Throwout case with most of the standoffs missing, HDD: Some old 80GB hard drive, PSU: Thermaltake Toughpower 550w, Monitor: 32" Kogan TV, OS: Fedora 13
 Laptop Which I Use For Everything:
Processor: Intel Core i5 3337U, RAM: 8GB (2*4GB) 1600MHZ, Graphics Card: Nvidia 710m HDD/SSD: WD Black2 Dual Drive, OS: Windows 8.1
 40 GB/s Network Tester
Processor: Some really good Intel Core i3, Motherboard: Gigabyte GA-H67N-USB3-B3, Ram: Corsair Value Select 4GB (2*2GB) 1600MHZ, Graphics Card: Integrated, Case: Some 1U rackmount mini-itx case with no front bays, HDD: Seagate Momentus 5400, 250GB 2.5" 5400RPM, PSU: Enchance 250W 80+ Bronze 1U power supply, CPU cooler: Cooljag double ball bearing 1U cooler (70DB! 70DB!), NIC: Mellanox 40Gb/s QSFP+ PCIe 3.0 8x NIC, Monitor: any ones lying around, or 32" Kogan TV, OS: CentOS 6.2 (I Think)
Planned 100Gb/s Newtork Tester
Processor: Intel Core i7 4790k, Motherboard: Asus Maximus VII Impact, Ram: Kingston or G.Skill 8GB 2400MHZ Low Profile, Graphics Card: Integrated, Case: 1U Rackmount ITX case, HDD: Samsung 850 EVO 120GB, PSU: Enchance 250W 80+ Bronze 1U power supply, CPU cooler: Cooljag double ball bearing 1U cooler (70DB! 70DB!), NIC: Mellanox 100Gb/s PCIe 3.0 16x NIC, Monitor: Any lying around or 32" Kogan TV, OS: Fedora 22 or CentOS
https://linustechtips.com/topic/438225-internet-help-urgent/
my guess is something on wireless is using all your bandwidth.
Edit: misread your post.
try reinstalling windows. some process on your PC is probably using all your bandwidth.
Recovering Apple addict
ASUS Zephyrus G14 2022
CPU: AMD Ryzen 9 6900HS GPU: AMD r680M / RX 6700S RAM: 16GB DDR5
https://linustechtips.com/topic/438225-internet-help-urgent/#findComment-5874815
