I have always wanted to overclock my hardware to get the most performance I could. I would like to know any websites, guides, documents, and other resources that I could access so I could learn more about this topic. If you have anything important that I need to know, please post below. Thanks in advance!
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/438221-how-do-i-overclock-and-do-it-safely/
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
Rule no. 1
Screw warranty.
Rule no. 2
Don't overclock when you're not willing to break it and blame someone else like the company.
Rule no. 3
Don't overclock if you're not even sure what you're doing 'because the guide is doing it'
don't use the stock heatsink.
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
Condom
xD
#RIPTopGear  This is the best thread ever: http://linustechtips.com/main/topic/53190-i-can-not-get-hard/ " French meetings are just people sitting in a semi-circle shouting at each other" -Dom Jolly  :lol:
My rig:
   CPU: Pentium G3258 @ 4.5GHz GPU: GTX 760 reference | PSU: Corsair RM750 Cooler: Cooler Master Seidon 120V | Motherboard: Gigabyte B85M D3H | Case: NZXT S340 White | RAM: 8GB EVO Potenza @ 1600MHz Storage: 3TB Seagate HDD, 60GB OCZ SSD, 620GB Toshiba HDD | Mouse: Steelseries Rival @1000 CPi |  OS: Windows 10 Pro Phone: iPhone 6S 16GB
http://linustechtips.com/main/topic/439354-why-nvidia/
ill nuke you
My rig:
GPU:
1. Get MSI Afterburner
2. Get Unigine Valley or Unigine Heaven benchmark
3. Start increasing core clock in Afterburner
4. Increase in small steps (~10MHz at a time), keep running benchmark in between
5. Increase until you see artifacting and/or glitching in benchmark
6. increase voltage by ~5mV, run benchmark again, keep an eye on GPU temperature
7. Rinse and repeat until highest stable clock at highest acceptable temperature (try to keep below ~85°C) is reached.
8. Follow same steps for VRAM overclocking, minus keeping an eye on the temperature. Just look for artifacting. Many cards won't let you change the VRAM voltage, just increase clock until you see artifacts, then dial it back a few MHz and you're done.
CPU:
1. Google search for an overclocking guide for your specific CPU or architecture (All unlocked Haswell chips overclock pretty much the same, for example). Make sure it's a good guide, nice and thorough.
2. Make sure you have decent cooling
3. Follow guide carefully, CPU overclocking requires a lot of patience
4. Don't forget to stress test appropriately. Stress test for ~20 min. in between steps, once you think you've got a decent result stress test for minimum 5 hours, 8 would be recommended, to confirm that the overclock is completely stable.
