So I'm gonna get my new PC soon and I was gonna put windows 8.1 on it and I am wondering if I am still eligible for the free windows 10 upgrade for a year since Windows will have been activated after the release of Windows 10.
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/436961-81-10-upgrade-help/
So you're getting a new PC but you won't have an activated copy of Windows on it? AFAIK you can still upgrade to 10 without issue even without a key but I'm not sure if that is legal or not.
https://linustechtips.com/topic/436961-81-10-upgrade-help/#findComment-5857419
its gonna be legal but its gonna be activated after the july 28th or when ever the date windows 10 came out im buying my key from G2A
https://linustechtips.com/topic/436961-81-10-upgrade-help/#findComment-5857439
I think you're solid my friend.
https://linustechtips.com/topic/436961-81-10-upgrade-help/#findComment-5857458
but when will I just be able to just buy windows 10 like in the stores
https://linustechtips.com/topic/436961-81-10-upgrade-help/#findComment-5857473
You can buy it now if you want... NCIX/B&H/Amazon, pretty sure they can be found here.
https://linustechtips.com/topic/436961-81-10-upgrade-help/#findComment-5857505
