Hi I need help im not sure if the NVIDIA GeForce GTX 970 is a better graphics card or is the MSI Radeon R9 390 better. This is the system build.
http://pcpartpicker.com/p/bxT4WZ
Reliable $550 Starter PC (http://pcpartpicker.com/p/KGgpZL) *Just waiting for someone to need help with there ram so I can make a downloadmoreram.com joke*
https://linustechtips.com/topic/436911-pc-help/
@FuriousGamer the R9 390 is better.
Isn't this a possibility?
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
CPU Cooler: RAIJINTEK TRITON RED 100.5 CFM Sleeve Bearing Liquid CPU Cooler  ($94.99 @ Newegg)
Motherboard: Gigabyte GA-Z97X-GAMING 7 ATX LGA1150 Motherboard  ($127.98 @ Newegg)
Memory: G.Skill Trident X Series 16GB (2 x 8GB) DDR3-2133 Memory  ($89.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.98 @ Best Buy)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card  ($688.99 @ SuperBiiz)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($108.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.99 @ NCIX US)
Total: $1528.89
Generated by PCPartPicker 2015-08-24 08:27 EDT-0400
Also there is a possibility of this:
i7-5820k + 980
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($378.99 @ SuperBiiz)
Motherboard: MSI X99S SLI Krait ATX LGA2011-3 Motherboard  ($202.99 @ SuperBiiz)
Memory: Mushkin Redline 8GB (2 x 4GB) DDR4-2400 Memory  ($61.99 @ Newegg)
Video Card: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 Video Card  ($494.99 @ NCIX US)
Total: $1530.90
Generated by PCPartPicker 2015-08-24 08:22 EDT-0400
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/436911-pc-help/#findComment-5856843
I would go 390 over the 970, more vram and slightly faster
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/436911-pc-help/#findComment-5856883
I would say 390 but you can't really go wrong with either card
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/436911-pc-help/#findComment-5856898
Im deciding to go with the 970 because the 390 is super power hungry.
It uses only 40W more than the 970
https://linustechtips.com/topic/436911-pc-help/#findComment-5857060
