12mm fittings with 13mm acrilic tubing
I've been searching for hours now and can't find what I'm looking for...
I want to use Bitspower fittings for the great looks and for the large selection of fittings. My problem is that I cannot find 12mm uv green tubing for the fittings. However, I have been able to find many 1/2" (12.7mm) tubing options that come in the colour I want. Which leads to my question, would a 12mm fitting work with the 12.7mm tubing? I know I would be a tight fit (if it actually did work) but I have only been able to find people trying it with the fitting being bigger than the tubing. I would try it myself but I have already spent too much money on this thing and it is time to play the broke student card.
If it will not work does anyone have any ideas on what I could use? I am heart set on the bitspower fittings and the smaller tubing. Also putting a die in the loop is a last resort, I would much rather stick with a distilled water, silver kill coil, and coloured tubing setup.
Thanks for your help.
my advice is get 12mm clear tubing and use uv green fluid like this, http://www.performance-pcs.com/mayhems-x1-coolant-1-liter-uv-yellow-green-19542.html
