Help with custom loop parts picking
Go to solution Solved by shypin,
check out my post here :) http://linustechtips.com/main/topic/433869-need-a-full-custom-loop-to-cool-cpu-2-970s/#entry5814948
dont get acrylic tubing btw, get PETG tubing instead as they are a lot more stronger
dont forget to get fittings for regid tubing instead of those for soft tubing
Hi guys,
I want to help my friend to build watercooled rig. It will be about watercooling overclocked 4790-K. He wants acrylic tubing, EK-Supremacy Evo waterblock, pure coolant (or UV blue) and 360 radiator. His budget now is about 250 bugs, but it very depends on local prices. I live in central Europe in Czech Republic. So also some tip where to buy would be awesome.
I told him that I am not confident his budget will be enough, so he is prepared for the worst allready :)
https://linustechtips.com/topic/436180-help-with-custom-loop-parts-picking/
-SNIP-
At $250 that's going to be very hard, you might be able to get a kit from EKWB to start and add in a GPU block afterwards but not with hardline tubing and at that pricepoint.
https://shop.ekwb.com/ek-kit-x360
