Choosing right potenciometer
Solved by slightlyjaded,
Yeah, you're probbaby right. So, what do you think will 1kOhm or 5 kOhm do it's job?
you're not very nice, you know that right...Okay assuming a noctua @0.1 amp max. 5V we're talking about 50 Ohm for the circuit. Assuming it's a linear progression for resistance to speed (it probably isn't but I don't know enough of the characteristics) @10% we're talking about 500 ohms. I would suggest overcompensating a little and using 1k, just because you can always turn the dial a little less, but it's really hard to turn the dial more than what the unit is rated for.
