GPU issue? or not?
Solved by Glenwing,
What connection are you using between your GPU and monitor, and what were you using between your motherboard and monitor?Sorry, its an AMD Radeon R9 280.
in the monitors menu there is only the option for wide or auto, neither work.
the reason I am assuming its a GPU issue is that its fine through the motherboard, it just automatically fits to the screen size.
cheers.
Try going to the Catalyst Control Center, go to Digital Flat Panel Scaling Options (or somthing like that) and play around with the slider. Ideally you'd want it to work at 0, but you can use the slider to underscan to compensate if you need to (though this will result in a fuzzier image).
