yep
Update to your latest BIOS. It might not support fully OC for windows 10 since I bet it's older. What is your motherboard?
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/435224-oc-does-not-work/#findComment-5833391
http://www.gigabyte.com/products/product-page.aspx?pid=5189#bios
You need the latest BIOS. The F3 release. You have to re flash it.
  1. Update CPU microcode for win10 support with Pentium AE
https://linustechtips.com/topic/435224-oc-does-not-work/#findComment-5834108
i.ve already got  the f3 bios
https://linustechtips.com/topic/435224-oc-does-not-work/#findComment-5834304
