oh boy this is going to be hard to explain but i'll try my best
so here is the situation I have my main RIG with 3 HDDs  2 500-GO and a 80go one  oh look maybe this will help
now i tried to just remove the HDD with windows 7 from the 1st pc and put it in the second BUUUUUUUTTT here are the problems  according to each PC
now i've re-put every HDD in the the main PC booted up choosed windows 10 and its works just FINE
""all i  want is to remove the HDD with windows 7 from my pc and put it in another PC thats all ""
thanks in advance and i hope someone can understand me
CPU: intel quad core Q9300 2.5GHZ GPU : amd HD7870 ghz edition 2go RAM : 6 go cheapo HDD: western digital 500GO + 80go seagate MOTHERBOARD :gigabyte G41mts2p CASE : cheapo  PSU: 2X 300watt DUAL psu setup MONITOR : asus VW223D
NOT the best and latest parts in the world BUT its working great for me
https://linustechtips.com/topic/435105-hdds-and-oss-problems/
-snip-
Okay, what are the specs of both PCs? Usually you cannot just move a OS to a new PC without clean installing it.
The way it's sounding though, it sounds like PC 2 is in UEFI mode and the Windows 7 drive is configured to run in BIOS (Just my guess).
I would heavily recommend cleaning installing Windows 7 onto PC 2.
https://linustechtips.com/topic/435105-hdds-and-oss-problems/#findComment-5831891
the first one is a  cpu Q9300 6gigs ram and a HD7870ghz edition  mobo g41MT S2P
 the second pc IS cpu G2020 2gigs ram no gpu and mobo H61 MLV3
a clean install would be easy but i have so much things in the drive "programs " that i need and reinstalling all of them is a pain in ... a pain
ok thanks for your help !
https://linustechtips.com/topic/435105-hdds-and-oss-problems/#findComment-5835735
