So I'm helping a friend with PC parts for his PC he's going to build. Some advice on the specs would be nice as I will list them below; however, he's planning on using a 2005 Sony Vaio VGC RB60G case as a case. It looks like a decent case to me, but I was hoping for some advice on whether it's a good choice or not. If everything fits, is the airflow good? Are the fans good enough to use? He's using it because his mother owns it already. The specs I've decided on are as follows:
CPU: i3 4160 3.6GHz
Motherboard: ASRock H97M Anniversary
Ram: Crucial 8GB 1x8 DDR3 1600MHz
Storage: WD Blue 1TB 7200RPM 64MB CASHE
GPU: Gigabyte Windforce GTX 750TI 2GB
Case: Read above.
PSU: EVGA W1 500w (I personally use it and it works fine. Not to mention it has great reviews and I've heard it's just a less efficient version of the B1 unit.
Monitor: http://www.amazon.com/Acer-G226HQL-Bbd-21-5-inch-Widescreen/dp/B009POS0GS/ref=sr_1_2?s=pc&ie=UTF8&qid=1440119794&sr=1-2&keywords=acer+monitor
He's buying everything off of Amazon.
PC and Peripherals:
Intel Core i3 4150 @3.5GHz - ASRock H97M Anniversary - Kingston Fury HyperX Black 8GB DDR3 @1866MHz - Gigabyte GeForce GTX 960 G1 Gaming 2GB GDDR5 - EVGA 500W 80+ Certified - WD Caviar Blue 1TB - WD Caviar Blue 160GB - Lian Li PC-50 - Linux Ubuntu 14.04.3 LTS - Acer P221w 21.5" 1680x1050 60Hz - Kingston Fury HyperX Clouds - Razer Deathadder 3.5G - CM Storm Quickfire Rapid w/ Cherry MX Blues
https://linustechtips.com/topic/434433-will-it-work/
From images on the case airflow is decent so airflow shouldn't be an issue. Hope everything does fit, which should looks like an ATX sized space for the motherboard.
Regards Elias N Martinez. | Graphic and motion design are my jobs. 3D modeling is my hobby. I do what I enjoy.  Skype: eliasnmartinez1 (please state that you are coming from LTT)
https://linustechtips.com/topic/434433-will-it-work/#findComment-5822429
Yeah, I was thinking airflow wouldn't be much of an issue. The motherboard I chose was Micro ATX which should be alright. I was mainly worried for the GPU, but I think it'll be fine.
PC and Peripherals:
https://linustechtips.com/topic/434433-will-it-work/#findComment-5822480
My honest opinion is get a case, consumer grade PC cases are not really good for rebuilding in them, some times motherboards are made to fit and its hard to work with that. If it works, go on with it.
https://linustechtips.com/topic/434433-will-it-work/#findComment-5822497
