1st build need help
Go to solution Solved by Senzelian,
That's a really nice little build! Absolutly nothing wrong here.
You won't need an aftermarket cooler for the i5, as long as you get the boxed version of the i5-4460.
The cooler that comes with it is for now good enough. If you want you can get a new cooler, which will look better and get you better temperatures.
But because you aren't able to overclock that CPU much, it isn't needed.
I might personally pick another motherboard, and if you're rolling 2 video cards that processor might give you some neckbottles (Yes, neckbottles)
2 graphics cards?
It's only one card. It's just the name that sounds a bit weird.
Okay so im going to be building a PC (for gaming) and i think the parts i have selected are good i just want another person opinion
Motherboard: ASRock Fatal1ty H97 Performance LGA 1150 CPU:  Intel Core i5-4460 Video card: MSI R9 380 GAMING 4G Radeon R9 380 4GB 256-Bit RAM: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 Hard drive: Western Digital Blue WD10EZEX 1TB 7200 RPM SSD: Crucial BX100 CT250BX100SSD1 2.5" 250GB SATA 6Gbps Case: Corsair Carbide Series SPEC-03 Black Steel ATX Mid Tower Gaming Case Power Supply: Cooler Master Elite V2 - 550W
Will i need an aftermarket cooler for the i5-4460??? I wont be overclocking
https://linustechtips.com/topic/434253-1st-build-need-help/
2 graphics cards?
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/434253-1st-build-need-help/#findComment-5820041
X99 WhoKnowsAnymore
CPU: Intel i7 5930K | Motherboard: MSI X99A Gaming Pro Carbon | GPU: EVGA GTX 1080 Ti Hybrid |
https://linustechtips.com/topic/434253-1st-build-need-help/#findComment-5820054
2 graphics cards?
https://linustechtips.com/topic/434253-1st-build-need-help/#findComment-5820062
hes not saying two graphics one section is just description of the other. The build looks solid. the above poster meant use pcpartpicker.com to set up your build in a more easy to read formet and it also provides the best prices/places to buy each individual part
https://linustechtips.com/topic/434253-1st-build-need-help/#findComment-5820104
Okay thanks for for help and also thanks for the graphics card help i thought i did something wrong since 2 people said about 2 cards
https://linustechtips.com/topic/434253-1st-build-need-help/#findComment-5820118
