I got a PC for christmas last year, and just recently I felt like I should try to overclock it. I have used my PC for gaming since ive got it and have never had any issues with over heating while play games, rendering videos or anything else. I watched one of Linus's videos about overclocking (
) and I followed through with what he did and proceeded to overclock my pc. My BCLK was 100.0 and my cpu was at 4.4 ghz, I set the voltage to 1.250, restarted my pc and stress tested it. Instantly my PC overheated to 88C and wouldn't get any lower. I went back and changed everything back to normal and restarted and stressed tested it again, my pc was completely fine with 55C while at 4.0ghz. I went back and forth changing the voltage and clock speed, the best I could manage to get was 4.4ghz with 1.150 voltage at 70C but anything over 4.4 would force me to put my voltage up and and make my PC overheat again. I don't know why putting it at anything higher than that would force my CPU to overheat so drastically when my cooler should be completely fine. Was hoping someone would help, I'm pretty new to this overclocking thing and I'm not really a "pro" when it comes to PC stuff either, I'm just learning, so try to speak somewhat understandable.
PC Specs:
Intel I7 4790k
Geforce GTX 770
Asus ROG Hero V z97
Corsair H100i liquid cooler
samsung 840 Evo SSD 250gb (X2)
Seasonic 750W Gold Plus power supply
https://linustechtips.com/topic/433750-cpu-overheating-when-overclocking/
Intel i7 Run High temps out of the Box
But your getting 88C with a Liquit cooler?
reapply new thermal paste and clean off the old stuff
"Life's too Short, Use Express Install" Express install subject to spying
                                        -Microsoft 2015
Did you use the H100i's pre applyed Thermal paste?
its pretty cheap stuff pre applyed
i clean it off and apply my own whenever i get a new cooler
                                        -Microsoft 2015
Yeah I did use the stuff that was pre-applied, mind you, I still can't see how im getting that high of temps but if nothing else comes up, ill try it
Maybe clean out your Radiator, is the Pump in the H100i Working correctly?
                                        -Microsoft 2015
Is the block mounted correctly?
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
The Pre-applyed stuff isn't bad, but it just sits in the box and can dry out and is very thin and doesnt work as well as applying your own
                                        -Microsoft 2015
I mean, when not overclocking it works completely fine even under stress testing with only 55C-60C at most so I don't feel like that's it, but I could check that aswell
Yes, I am 100% sure it is, ive had it like this since Christmas and it has worked fine until i tried overclocking
Idle temps?
My Friend who has a Intel I7 4790k and a H105 gets 25C at Idle and a max of 39C at heavy load(Gaming)
                                        -Microsoft 2015
hmm makesure the pumps plugged into the MOBO correctly
and apply new Thermal paste
                                        -Microsoft 2015
Pumps are all good, will new thermal paste really do anything. When we first took the cooler out of the box we checked the paste to see if it was good and it felt fine, it wasn't tough or anything, could it really have gone bad in 6 months?
Does the pump use a USB input or fan controller input?
Is it plugged into the correct place ?
Make sure whatever controller it is plugged into is not throttling back the pump speed or not allowing it to go higher during heat up.
Had that problem once with a client's pc, he had a liquid cooler plugged into the fan controller but the specs clearly stated to plug the USB input to a USB on the MB and then plug the radiator fan into the other end of that setup.
No clue why but it ran like it was supposed to once it was installed correctly.
Go figure
FX-8320 @3.79 - Corsair H80i - Gigabyte GTX 970 WF - Asus Sabertooth - EVGA Supernova 650 P2 80+ Platinum - Thermaltake Commander Black
--- Twitter: @Armchairgooroo    FB: Thearmchairguru    Twitch: armchairguru ---
Go figure
Pump is moving at 2200 RPM
1) Wherever you have your pump plugged in ensure that in your bios that fan controller is either on full speed (not the same as turbo), manually set to 100% for all temperatures, or fan control is turned off for that fan port (which defaults to 100%). Your Corsair liquid cooler always needs the full 12 volts.
2) Reapply thermal paste after cleaning off the stock thermal paste. Your connection between your cooler plate and CPU may have gaps.
3) Ensure that your cooler plate is securely fastened to your CPU housing. Try moving it, if it's loose you need to tighten it.
4) A few no brainer stuff, but hey, could happen. Ensure you took off the plastic cap that came on the motherboard which separates the processor from the cooler. Ensure you took off the plastic housing the cooler plate had on it when shipped. Ensure that you have fans on your radiator blowing or pulling out of your case (fan alignment is everything.
5) Try testing with an open case (take off your side cover) and see what temps you get.
6) Try testing with a cooler room (turn AC on) and see what temps you get.
Done, same temps
Ordered some, gonna do it in a day or so when it gets here
Its as tight as it can get, no movement at all
Yup, the are sucking it the cold air outside my case and blowing it inside
Yup, I opened the side panel and temps are still the same
Air conditioning was on every time and my room was cool plus I had my fan on and another fan blowing directly onto my computer (Don't actually know the temps of my room but below 75F)
Your CPU could just be a dud in the silicone oc market.  It happens.  You might just have to shoot for a lower clock speed.
Even at turbo which only brings it to 4.2 not even 4.4 it goes up to 70-75C :/ I guess it really is a dud, or there is something so random that I could never think of that is causing the problem... so probably a dud.
At least you got a great CPU...a dud one, but still a great CPU.  I don't think ya can return or RMA it though since you did push past the turbo.
I know, ah well, still has good performance, doubt overclocking would change it that much anyways, more of a bragging right :P
