Hey all, I installed a new 240gb Sandisk plus SSD into my system to store games with slow loading times (e.g bf4). After I launched bf4, I noticed that loading times weren't significantly faster- from 3 minutes on the hard drive to over 2 minutes on the ssd. I know it's not the game because I remember when I had the game on my boot drive (840 evo) loading times were <30 seconds (I moved it off the evo due to lack of space). I'm not sure if this is an SSD problem. Thanks for your help.
https://linustechtips.com/topic/433663-ssd-slower-than-expected/
Did you plug it in using your motherboard's sata 6 gb plug?
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/433663-ssd-slower-than-expected/#findComment-5812194
turn on AHCI in bios, then enable trim function for your SSD.
https://linustechtips.com/topic/433663-ssd-slower-than-expected/#findComment-5812212
Make sure you plug it in a SATA 3.0 port, and not 2.0. The difference will be about 40% more speed.
Also, BF4 maps won't launch within 2 minutes, even with a SSD.
Mine launch in less than a minute usually at 1440p............ <.<
His SSD is known to not be very speedy or reliable.
https://linustechtips.com/topic/433663-ssd-slower-than-expected/#findComment-5812214
Yes It's in a SATA 3 port. Oh well, I may just have to live with it.
https://linustechtips.com/topic/433663-ssd-slower-than-expected/#findComment-5812256
