The problem is that  the card isn't getting the fps it is  supposed to. For example running the hitman  benchmark at 1920x1200 I am getting 63 fps while guru3d shows fps in the 90s (using the same settings). My system  is a 2500k, 12gigs of ram, 520 watt psu. I have installed the latest drivers. Anybody know what  could be causing the slowdown or how I can start trouble shooting?
https://linustechtips.com/topic/433614-amd-390-problem/
Check with software like MSI afterburner if your GPU is hitting 100% or your CPU. Please test this real quick (you'll see really quickly) and return with results please. And don't use taskmanager, it's useless.
^^ this
Your i5 might be lagging a bit in some cpu intensive games
Recommend what is best, not what you preffer.
"Like" comments to show your support of them or the idea they express.
https://linustechtips.com/topic/433614-amd-390-problem/#findComment-5811527
