So I'm in the middle of building my PC and decided to get some opinions on my parts. Also some suggestions for parts would be great. For example, I have a GTX 960 SSC on my list but should I spend a few extra bucks on the 970 instead. I have my case, mobo, PSU and cd drive. My build theme is white, soooo obviously that is a big influence on some of my choices. I'm mainly going to be playing games like LoL, CS: GO and Minecraft. I'll also be streaming to twitch. I eventually want to get into other PC games like BF. Well here is the link to my list: http://pcpartpicker.com/p/wyb9zy
https://linustechtips.com/topic/433185-pc-build-opinions/
Just so everyone can see
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($279.99 @ Micro Center)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($139.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX 960 4GB SuperSC ACX 2.0+ Video Card  ($229.99 @ Amazon)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($109.99 @ Newegg)
Optical Drive: Asus BC-12B1ST/BLK/B/AS Blu-Ray Reader, DVD/CD Writer  ($52.98 @ OutletPC)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($88.88 @ NCIX US)
Case Fan: Noctua NF-A14 PWM 82.5 CFM 140mm  Fan  ($23.25 @ Amazon)
Case Fan: Corsair CO-9050017-WLED 66.4 CFM 140mm  Fan  ($14.79 @ OutletPC)
Monitor: Acer XB270HU bprz 144Hz 27.0" Monitor  ($799.99 @ Micro Center)
Keyboard: Corsair K70 RGB Wired Gaming Keyboard  ($139.99 @ Amazon)
Total: $2277.33
Generated by PCPartPicker 2015-08-19 01:38 EDT-0400
CPU: Intel i5-2400 Mobo: ASUS Maximus IV Gene-Z RAM: 8GB G.Skill DDR3 1333MHz GPU: Sapphire R9 280x Tri-X Case Corsair Obsidian Series 350D PSU: EVGA 500w 80+ Certified
https://linustechtips.com/topic/433185-pc-build-opinions/#findComment-5806126
1) Yes, a 970 is definitely worth the extra cash in regards to its performance
2) A 860w platinum PSU isnt worth the money, and the money saved from that can be used towards the 970 mentioned above.
I suggest maybe this: http://pcpartpicker.com/part/cooler-master-power-supply-rs650amaag1 , or if fully-modular is what your after, then maybe: http://pcpartpicker.com/part/corsair-power-supply-cp9020072
https://linustechtips.com/topic/433185-pc-build-opinions/#findComment-5806152
2) A 860w platinum PSU isnt worth the money, and the money saved fromt hat can be used towards the 970 mentioned above.
I already bought the PSU. Got it pre-owned and on sale for Newegg for about $80 I think. Seen the price and really couldn't pass it up. I know 86o is really overkill for my build. The 750 you linked is nice though. Might get it for my fiancees build.
https://linustechtips.com/topic/433185-pc-build-opinions/#findComment-5806180
do you plan on playing any games at 1440p or 1080p? if you only plan to play at 1080p you could probably get cheaper monitor. also I would probably swap that i7 for an i5 like the 4690k and just OC it and definitely get a 970. if you saved in other areas, you could probably extend a bit further and get a 980
https://linustechtips.com/topic/433185-pc-build-opinions/#findComment-5806183
Oh dayum thats a nice price considering it is pre-owned. Anyways, it gives you more options to eventually add another 970 if you feel like it.
https://linustechtips.com/topic/433185-pc-build-opinions/#findComment-5806191
