Four, If I recall. 1 140 mm in the back and three 120's in the front.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/43303-900d-fans/#findComment-565182
Pretty much everyone's a fan of the 900D. Except me!
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/43303-900d-fans/#findComment-565306
There are three 120mm intake fans and one 140mm exhaust fan. They are not bad, but a bit too loud. I switched all the fans to SP120 quiet editions and one AF140 (the fan at the back). I even replaced the H100i fans to SP120's.
Intel i7 4770k | Corsair H100i | Asus Maximus VI Extreme | 16Gb Corsair Dominator Platinum 1866MHz | Asus GTX 780 SLI | Samsung 830 Pro 256GB + 6TB WD Red | Asus Xonar Phoebus | Corsair AX860i | Corsair 900D | Win 8 Pro 64-bit | 2 x Dell U2412M | Logitech G710+ | Logitech G602
https://linustechtips.com/topic/43303-900d-fans/#findComment-566068
