So i am buying new PC. Intel based (4670). And i dont know wich of these mobo. wil be best for gaming:
http://www.asrock.com/mb/Intel/Fatal1ty%20H87%20Performance/
http://uk.asus.com/Motherboards/Intel_Socket_1150/H87PRO/#specifications
http://www.gigabyte.com/products/product-page.aspx?pid=4491#ov
I would take one of these
>WaRRioR_ would like quake full and final....will trade vital organs.\"
5960x, rampage v extreme, 2x 16Gb ddr4 g skil 2400mhz ram, 2x 2tb black WD, 4x samsung pro 256Gb, 3x gtx 980 evga superclocked, Corsair ax1200w, define r4, noctua nhd15, 4x dell u2412m....
https://linustechtips.com/topic/43299-best-mid-range-mobo/
  • Get the one the will soothe you color Scheme
  • Or whichever is cheaper
  • or whichever has the PCI or IO connectors that soothes you best
Cause both are awesome manufacturers. Personally I'd go with Asus cause I'm a fanboy but I heard Gigabyte is really durable. :P
CPU: i5 -2400 Cooler: Noctua NH-L12 Mobo: Fatal1ty Z68 Pro Gen3 Memory: Corsair Vengeance 8gb 1600mhz SSD: Samsung 840 120gb HDD: WD 3TB Green, Seagate Barracuda 1TB GPU: Asus GTX 760 Direct CU II (future SLI) Sound card: Xonar Phoebus PSU: Corsair RM series 750 watts Case: Aerocool Mechatron Fans: Bit Fenix Spectre Pros
Monitor:Samsung SyncMaster SA950, Philips Blade 234CLSpeakers: Logitech z506 Headset: Razer Tiamat 7.1 KB: Blackwidow Ultimate Stealth edition Mouse: Ouroburos Mouse pad: Golaithus Extended Speed edition Gamepad: Orbweaver Controllers: Wireless Xbox 360 Controller, Razer Hydra
System: Razer Edge Mouse: Razer Orochi Mouse pad: Razer Vespula Controlers: Razer Sabertooth (2 pcs.) Headset: Razer Blackshark Speakers: Razer Ferox What can I say, I'm a huge fan of Razer.  :D
https://linustechtips.com/topic/43299-best-mid-range-mobo/#findComment-565114
Why H87 chipset? You can get z87-k or z87-c frm asus and there are only 20$ difference.
I don't think he plans to OC. :)
https://linustechtips.com/topic/43299-best-mid-range-mobo/#findComment-565116
Personally I would go for the gigabyte I have had many issues with asrock and am not a fan of the gold on the asus although it is all personal preference.
Try looking at some msi boards as well perhaps:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-235-MS&groupid=701&catid=5&subcat=2574
http://www.overclockers.co.uk/showproduct.php?prodid=MB-234-MS&groupid=701&catid=5&subcat=2574
So I spelt something wrong in my post... I don't care I don't read through what I write and I type very quickly.
Intel 3770k stock, MSI Z77A-GD65, MSI GTX 760, Corsair Vengence DDR3 1600Mhz 16Gb, Corsair RM 550W, Samsung 830 256Gb, some random hdds.
https://linustechtips.com/topic/43299-best-mid-range-mobo/#findComment-565301
The motherboard doesn't really affect performance.
Just get the cheapest B85 or H87 motherboard you can find--whichever is cheaper.
https://linustechtips.com/topic/43299-best-mid-range-mobo/#findComment-569708
