fan overcloking
Solved by wardude1,
I don't know anyting about this, but this idea is cool af, so I am following it
well since you are intrestate
I have overclocked my 3 bitfenix spectre pro 230mm to 17 volt using the -12 volt rail as a ground and the 5 volt rail as a voltage line which resultate in a 17 volt difference. the fans are now powerfull enough to use the table as an air hockey table (244 cm by 122 cm)
if you have some more questions just quote my post or message me
