A custom program/script MIGHT work for something like this, IDK though.
#RIPTopGear  This is the best thread ever: http://linustechtips.com/main/topic/53190-i-can-not-get-hard/ " French meetings are just people sitting in a semi-circle shouting at each other" -Dom Jolly  :lol:
My rig:
   CPU: Pentium G3258 @ 4.5GHz GPU: GTX 760 reference | PSU: Corsair RM750 Cooler: Cooler Master Seidon 120V | Motherboard: Gigabyte B85M D3H | Case: NZXT S340 White | RAM: 8GB EVO Potenza @ 1600MHz Storage: 3TB Seagate HDD, 60GB OCZ SSD, 620GB Toshiba HDD | Mouse: Steelseries Rival @1000 CPi |  OS: Windows 10 Pro Phone: iPhone 6S 16GB
http://linustechtips.com/main/topic/439354-why-nvidia/
https://linustechtips.com/topic/432215-bluetooth-mouse-help/#findComment-5794288
wireless =/= bluetooth
wireless is not necessarily equal to bluetooth
for example the universal receiver from Logitech is wireless but it's not exactly bluetooth, if you are sure about the fact that your mouse is bluetooth than it should connect with any bluetooth compliant receiver .
https://linustechtips.com/topic/432215-bluetooth-mouse-help/#findComment-5794302
If it's a Logitech mouse with a unifying receiver you can just get a new wireless receiver and pair the device again. If it's actually Bluetooth it wouldn't have needed the adapter in the first place unless you have a MX Master which has both.
i5 4670 | Asrock Fatal1ty H87 | G.Skill 16GB snipars | Gigabyte GTX 760 Windforce | CM 690 III | 850 Evo 250GB + 2TB Seagate Barracuda | Seasonic G-750 | Logitech G502 | AKG K553 | Windows 10
https://linustechtips.com/topic/432215-bluetooth-mouse-help/#findComment-5795081
