Hi dude.
Any recommendations on a 200mm fan?
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
https://linustechtips.com/topic/431979-200mm-fan/
Hi dude.
Only good brand 200mm fan i'm aware of is the 200mm Bitfenix Specter pro. There are more options on the 180mm size. There is also the Cooler master Mega flow, but i find CM's fan quality to be lacking in almost all cases, with the silencio FP being the exception.
http://www.amazon.com/BitFenix-BFF-SPRO-20025KK-RP-Cooling-200mm-Case/dp/B0067LYYI0/ref=sr_1_2?ie=UTF8&qid=1439827434&sr=8-2&keywords=bitfenix+spectre+pro+200mm
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/431979-200mm-fan/#findComment-5791581
I'd look into the Bitfenix 200mm option. I've got a pair of the CM megaflows, but they're not that great. They're not bad, I just wasnt all that impressed.
That's like CM slogan, not bad but not impresive...the ones that came with my case barely moved any air.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/431979-200mm-fan/#findComment-5791607
