so i just got a laptop from a friend and it hasnt got any drivers on it , i found all the ones i need and have installed them but i cant find the right audio driver
the Laptop is a Lenovo G580
can anyone find it ?
EDIT : im on windows 10
My Pc Specs
CPU : AMD FX-8350 @stock w/Noctua NH D-14   Mobo: Asus M5A99FX    Ram : 16gb Corsair XMS3 @1600mhz    GPU : Gigabyte GTX970 Windforce OC 4GB @1429mhz   SSD: Sandisk X110 256gb    Case: Be Quiet Silent Base 800 Windowed  PSU: EVGA 850w g2  Peripherals : Corsair K70 w/Red Switches , Logitech G502 , Samsung SyncMaster S22B300 (1920x1080) , Ttesports Shock one headset , Phone : HTC one A9
https://linustechtips.com/topic/431391-what-audio-driver-do-i-need/
You need the Conexant Audio Driver, if your runnung windows 8.1 (64bit) on the laptop it should be the right one.
http://support.lenovo.com/us/en/products/laptops-and-netbooks/lenovo-g-series-laptops/lenovo-g580-notebook/downloads/DS037354
By the way I know you said you found all the drivers but could not find the the audio driver but if you go on the lenovo website under "Official Lenovo support home > laptops > Lenovo G seriees laptops > G580 Laptop (lenovo) > Downloads". This is where you'll find all the drivers for most operating systems.
