AHCI setting
Go to solution Solved by Speedbird,
So I have an SSD AND a HDD. I want to turn on AHCI, but it doesn't work for hard drives. How do I turn it on for a specific drive. I have the MSI Click BIOS.
It does work for hard drives. In fact, it was designed for hard drives. That is why NVME is important.
LTT's unofficial Windows activation expert.
https://linustechtips.com/topic/430887-ahci-setting/#findComment-5777637
If its a really old hard drive, you have to turn to IDE Mode (if you have HDD with that bulky cable)
I successfully hacked 127.0.0.1! Now I cant turn on my computer :/
6700K - z170 Pro Gaming - Samsung 850 Pro 256GB - WD Black 1TB - WD Green 3TB - External Hard drive 3TB - Zotac GTX 970 Amp! Core Edition - Fractal Define R5 - RM650 - Razer BW Chroma - Roccat Tyon Lasermouse
https://linustechtips.com/topic/430887-ahci-setting/#findComment-5783577
As others have stated, it will work with the HDD. Your issue will be that Windows will be blue screening due to being configured for IDE drives
https://linustechtips.com/topic/430887-ahci-setting/#findComment-5785800
