Hey im building a gaming pc for the first time and i think this is a good setup but if anyone can suggest better parts please tell me
CPU: Intel Core i3-4160 Haswell Dual-Core 3.6GHz LGA 1150 54W Video card: MSI R9 380 GAMING 4G Radeon R9 380 4GB 256-Bit Motherboard: GIGABYTE GA-H97-D3H LGA 1150 Intel H97  RAM: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 Hard drive: Western Digital Blue WD10EZEX 1TB 7200 RPM SSD: Crucial BX100 CT250BX100SSD1 2.5" 250GB SATA 6Gbps Case: Rosewill CHALLENGER - Black Gaming ATX Mid Tower Computer Case Power Supply: CORSAIR CSM Series CS550M 550W
Also i will be upgrading the CPU to a Intel Core i5-4690K
https://linustechtips.com/topic/430759-i-need-help/
whats your budget and currency
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
https://linustechtips.com/topic/430759-i-need-help/#findComment-5775841
Currency is euro and i dont really have a budget but im trying to stay under 700 euro
ok give me a minute and i'll see what I can do
https://linustechtips.com/topic/430759-i-need-help/#findComment-5775893
here I wasn't sure what country you ive in so I just chose germany
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor  (€121.85 @ Amazon Deutschland)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  (€85.34 @ Home of Hardware DE)
Memory: Kingston HyperX Fury Blue 8GB (1 x 8GB) DDR3-1600 Memory  (€45.66 @ Amazon Deutschland)
Storage: Sandisk Ultra Plus 256GB 2.5" Solid State Drive  (€85.20 @ Home of Hardware DE)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€55.00 @ Amazon Deutschland)
Video Card: MSI Radeon R9 380 2GB Video Card  (€216.09 @ Amazon Deutschland)
Case: Cooler Master K280 ATX Mid Tower Case  (€38.78 @ Amazon Deutschland)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  (€81.15 @ Amazon Deutschland)
Total: €729.07
Generated by PCPartPicker 2015-08-15 21:36 CEST+0200
https://linustechtips.com/topic/430759-i-need-help/#findComment-5775962
this build is much better than your original
edit:
i would recommend a 4 core processor at the minimum for gaming
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($193.00 @ NCIX US)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($70.98 @ Newegg)
Memory: Team Elite Plus 8GB (2 x 4GB) DDR3-1600 Memory  ($37.99 @ Newegg)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($44.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($47.99 @ SuperBiiz)
Video Card: Gigabyte Radeon R9 380 4GB SOC Video Card  ($228.99 @ SuperBiiz)
Case: Fractal Design Define S w/Window ATX Mid Tower Case  ($79.99 @ NCIX US)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($64.99 @ SuperBiiz)
Total: $768.92 or 692.07 EURO
Generated by PCPartPicker 2015-08-15 15:38 EDT-0400
BigDay
https://linustechtips.com/topic/430759-i-need-help/#findComment-5775973
Not a big fan of the CS550M psu. It is not a bad unit, but there are better units that are usually competitively priced. http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=366
Don't plan on upgrading a cpu. It generally will not happen. Usually because by the time one is ready to upgrade compatible models are either unavailable or quite expensive. But also because the latest generation offers better performance and pricing. But if you wish to disregard this advice, at least get a Z97 motherboard so that when (if) you upgrade to an i5-4690K you will be able to take advantage of it being unlocked, i.e. you will be able to overclock the little beastie.
https://linustechtips.com/topic/430759-i-need-help/#findComment-5776039
