Okay so i will be joining the PC master race and i was wondering if this is a good setup or should i change anything
CPU: Intel Core i3-4160 Haswell Dual-Core 3.6GHz LGA 1150 54W Motherboard: ASUS ROG MAXIMUS VII HERO LGA 1150 Intel Z97 Video card: MSI R9 380 GAMING 4G Radeon R9 380 4GB 256-Bit RAM: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 Hard drive: Western Digital Blue WD10EZEX 1TB 7200 RPM SSD: Crucial BX100 CT250BX100SSD1 2.5" 250GB SATA 6Gbps Case: Rosewill CHALLENGER - Black Gaming ATX Mid Tower Computer Case Power Supply: CORSAIR CSM Series CS550M 550W
Also any tips or help will be much apreciated
https://linustechtips.com/topic/430659-first-pc-build/
What's your budget and location?
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/430659-first-pc-build/#findComment-5774657
Why a overpriced motherboard, get a cheap H81 or H97 motherboard and you could upgrade the CPU to a i5 also get a better quality PSU as the CSM isn't that good and get a better mid tower case because that one has poor cable management
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/430659-first-pc-build/#findComment-5774667
use pcpartpicker
My Build: i7-4790K, 212 Evo, Asus Maximus VI Extreme, Crucial Ballistix Sport 16GB DDR3-1600, Intel 730 240GB SSD, WD Blue 1TB, EVGA GTX 980Ti ACX 2.0, NZXT H440 Blue/Black, EVGA 650W 80+Gold.
Most of the time, it's not the computer, it's the person using it.
https://linustechtips.com/topic/430659-first-pc-build/#findComment-5774773
Can you reccomend a motherboard, PSU  and a case???????
Im new at this whole pc thing
https://linustechtips.com/topic/430659-first-pc-build/#findComment-5774788
