Sol Republic Tracks Air
I've had these for close to two years I think.  Excellent.
The only downside to these is the "battery low" message.  It's fairly annoying, but you can listen to music for 12 hours straight on a single charge.
The battery only takes 15 minutes to fully charge.  I'd purchase another pair in a heartbeat.
https://linustechtips.com/topic/429663-wireless-headphones/#findComment-5762149
Sennhizer rs-175.... good docking station and you can hook your phone right up to it... unless your looking for a simple bluetooth headset with small ear buds and then id recommend anything from LG, i have the lg tone and any model of them will do wonders
https://linustechtips.com/topic/429663-wireless-headphones/#findComment-5762167
