Hey all,
I tested this and i believe it works but i think it may be wrong.
Can anyone skilled in creating events help me correct the code. Thanks!
What i want to achieve:
It updates a field (flag) in a table (mytable) with a value of 0 after a certain time (6 hours and 10 minutes from when it was created) then removes itself from the scheduler. So i click a button, it creates the event and after 6 hours and 10 minutes the event sets flag = 0 and removes itself.
Code:
CREATE EVENT myevent ON SCHEDULE EVERY 6 HOUR STARTS CURRENT_TIMESTAMP + INTERVAL 6 HOUR + INTERVAL 10 MINUTE ENDS CURRENT_TIMESTAMP + INTERVAL 6 HOUR + INTERVAL 11 MINUTE DO UPDATE mytable SET flag = 0
     ~ Live Love Code ~
https://linustechtips.com/topic/429336-mysql-help-with-event/
Why do you think it is wrong, if it works?
I am using it on a client server and he insists that it does not stay for 6 hrs and 10 min but i tested it on my local server and it works.
I just want someone to review it and see if the syntax is correct.
     ~ Live Love Code ~
https://linustechtips.com/topic/429336-mysql-help-with-event/#findComment-5758229
Are you able to test it on their server?
https://linustechtips.com/topic/429336-mysql-help-with-event/#findComment-5758354
Versions of MySQL running on your server and his?
Are the schemas the same?
How is this being added?
Php and database schema are the same.
I am using the codeigniter framework so when a form gets submitted the code is executed directly on the db.
So there is nothing wrong with the code?
     ~ Live Love Code ~
https://linustechtips.com/topic/429336-mysql-help-with-event/#findComment-5791553
