I am trying to get a mini-itx build going for a friend. Her budget is 550 USD. She doesn't need an OS. It is for gaming and general use.
I had this going: http://pcpartpicker.com/p/cmyLTW
But I know you guys can do better. Thanks a ton! :)
Quote my post if you need me to respond.
https://linustechtips.com/topic/428984-mini-itx-build/
http://pcpartpicker.com/p/ndjqnQ The best I could do.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/428984-mini-itx-build/#findComment-5753914
Seems fine but PSU seems a bit overkill.
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
https://linustechtips.com/topic/428984-mini-itx-build/#findComment-5753917
Get rid of that CX PSU. They are terrible.
For the higher wattage ones they are pretty bad, but for those lower ones they are fine.
My Rigs:
Case:
Case:
https://linustechtips.com/topic/428984-mini-itx-build/#findComment-5753928
Beat ya ;)
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor ($112.99 @ SuperBiiz)
Motherboard: MSI H81I Mini ITX LGA1150 Motherboard ($62.99 @ Directron)
Memory: Kingston Savage 8GB (1 x 8GB) DDR3-1600 Memory ($39.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($48.89 @ OutletPC)
Video Card: PowerColor Radeon R9 380 2GB PCS+ Video Card ($198.99 @ SuperBiiz)
Case: Cooler Master Elite 130 Mini ITX Tower Case ($42.70 @ Mwave)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($44.99 @ Amazon)
Total: $551.54
Generated by PCPartPicker 2015-08-13 01:25 EDT-0400
Despite its fairly unknown branding, PowerColors PCS+ is actually very good. Managed to squeeze an R9 380 in their, updated the case, added a less overkill PSU and changed the mobo to an H81, which is cheaper and works just as well.
https://linustechtips.com/topic/428984-mini-itx-build/#findComment-5753958
Beat ya ;)
Total: $551.54
Over budget by way to much.
/s
//Does not work. Needs fixing
https://linustechtips.com/topic/428984-mini-itx-build/#findComment-5753975
/s
>$1.54
Damn son. Cant buy it now I guess
My Rigs:
Case:
Case:
https://linustechtips.com/topic/428984-mini-itx-build/#findComment-5754037
Beat ya ;)
Total: $551.54
You don't have a SSD that is very important.
https://linustechtips.com/topic/428984-mini-itx-build/#findComment-5757700
