Hi,
Is there any way to prevent Windows 10 from reinstalling drivers? Specifically, Realtek HD Audio. I've uninstalled it several times, but the OS keeps reinstalling it. How do I stop it?
On my system I swapped out the driver using device manager, and it hasn't set the Realtek ones as default since. I left instructions on how to do this in another thread; I'm gone to find it and put the URL here.
Edit
https://linustechtips.com/main/topic/424332-how-to-boost-bass-in-windows-10/
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
https://linustechtips.com/topic/428923-realtek-hd-audio-driver/#findComment-5753186
You need Realtek Drivers daheck?Do you have a separate sound card or something?
I would suggest you read the post again.
Edit
Thank you! :D
https://linustechtips.com/topic/428923-realtek-hd-audio-driver/#findComment-5753271
