USB 3.0 Card Power?
Solved by iamdarkyoshi,
Alright, so basically, I'm going to get the card and try it with and without the "recommended" molex power and see if it works. I mainly want to use it for an external Seagate harddrive and that drive already has it's own AC adapter type of power supply. The USB 3.0 will only be for transferring the data.
It should be completely fine. From an engineering standpoint, the only advantage that I see is that it gets its 5v rail directly from the supply rather than going through the motherboard. But if the board cant supply a clean 5v rail, its too crappy to even need a usb 3.0 card anyway lol
