Hey i am using a a corsair obsidian 900D, and i need alot of fans, but i also want to use a exsternal fan controller, so i buyed a adapter for fans, but the adapter doesnt fit with exstarnal fan controller, please help.
Sorry for bad grammar.
Fan splitter is: ekwb ek-cable splitter 4-fan pwm extend
Exsternal fan controller is: NZXT SENTRY LXE External Fan Control
https://linustechtips.com/topic/428491-need-help-with-fan-splitters/
you need a 4pin pwm female  to a 3pin male
Case:- 4U Rack Mount Case | Cooler:- Antec Kuhler H600 | CPU:- Intel i5 4690K @ 4.50GHz GPU:- Zotac GeForce GTX 970 4GB AMP! Omega Core Edition @ 1449MHz | Motherboard:- MSI Z97S SLI Krait | PSU:- XFX XTR 650W Gold | RAM:- HyperX DDR3 1866MHz 4GB White (x2) Black (x2) | Storage:- Kingston V300 120GB | Storage 2:- Seagate FireCuda 1TB | Build Log |
Welcome to the Forums!
Note how much power your drawing from a single channel to not overload the controller but you need 3 pin splitters since it's a 3pin fan controller. The splitter cable you have is fore direct 12V power and control via PWM.
You need to get a 3-pin splitter instead of a 4-pin pwm one.
Here are some examples:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812406015
http://www.performance-pcs.com/modmytoys-3-pin-power-distribution-pcb-5-way-block.html
