Today I received my XFX reference R9 290 from a seller on eBay. Card is immaculately (was used for mining for 2 months). I received everything with the card, but the serial number on the warrenty information is different to the one on the on the cards sticker. Just wondering if they are ment to be linked or if I could just use the one on the information piece of paper with the serial number on the card?
Thanks,
Paddy.
Current PC - CPU: 3570k stock, Motherboard: ASUS P8Z77-V LX2, Video card: R9 290 Referance, RAM: 8GB HyperX Beast 1600Mhz @1.5v, PSU: SeaSonic Bronze 520w, Case: Cooler Master HAF 912 Advanced
https://linustechtips.com/topic/428449-warranty-help-please/
Warranty? eBay?
You got ripped off. The serial numbers need to correspond.
If it was used for mining I wouldn't stress it too much (or hope that it lasts too long). That's 2 months of 24/7 operation at, presumably, full load.
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/428449-warranty-help-please/#findComment-5747193
Warranty? eBay?
More than full load - furmark-style load.
https://linustechtips.com/topic/428449-warranty-help-please/#findComment-5747197
didn't want to go deeper into the subject
My dad used to have a 2-way GTX770 SLI. Both cards were used for BTC mining for about 5 months. Needless to say one of the cards is now about as dead as a dodo and I expect the second one will follow (since the card that still works was the second GPU, it might have been spared from too much load on my dad's rig)
https://linustechtips.com/topic/428449-warranty-help-please/#findComment-5747218
Warranty? eBay?
I'll just message the guy he will hopefully still have it kicking around, if not I'm not that bothered about it.
https://linustechtips.com/topic/428449-warranty-help-please/#findComment-5747242
Furmark and Bitcoin are bad :/
https://linustechtips.com/topic/428449-warranty-help-please/#findComment-5747274
Especially for nVidia cards
AMD tend to survive more?
https://linustechtips.com/topic/428449-warranty-help-please/#findComment-5751827
Well, from what I hear for Dogecoin mining?
https://linustechtips.com/topic/428449-warranty-help-please/#findComment-5777029
Thanks,
Paddy.
I'd get a refund, a mined card without a warranty is worthless.
https://linustechtips.com/topic/428449-warranty-help-please/#findComment-5777257
