Laptop hard drive issues.
So i should do a clean instal to prevent windows from generating corrupted files? I guess if it cant hurt the drive further than thats what i will do. If i find there to be no issues after the fresh install which diagnostics should i run to make sure there arent any issues with the hard drive (bad sectors is a thing ive heard a lot)?
Thanks guys
Yea, sometime the disk check errors aren't from a bad disk itself but rather from a bad filing system.
But if it makes it worse, or doesn't make it better, you're still (no matter what) going to have to get a new drive.
Window's built in Disk Check is MORE than sufficient to ensure proper operation. And it isn't about Window's generating more errors, it's about the potential that it is just filing system based.
