Audio not working in csgo
TRambo
So i recently purchased a Hyper X Cloud 2 Headset. Im using the usb sound card or whatever to connect it to a usb 3.0 port. It works fine with skype. However it isnt working with youtube and csgo. Please help.
Have you selected the audio device you want to use in steam?
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
Make it your default sound device.
Right click on your volume control in your task bar, click playback devices, click on Headset Earphone (HyperX 7.1 audio device), and then click Set Default.
(Also make sure you re launch cs after doing that)
PC Specs: CPU: Intel Core i7 3930K OC @ 4.4 GHz | CPU Cooler: Corsair H105 | Motherboard: ASUS Sabertooth X79 | GPU: 2x SLI Gigabyte GTX 760 | RAM: Mushkin Redline 2x4GB 1866 | Case: Cooler Master HAF X | PSU: SeaSonic X Series 750W | Storage: A-Data XPG 120GB  & WD Blue 1TB | OS: Arch GNU/Linux || PC Part Picker & 3D Mark Score
