This will be my first pc and I want help getting a good graphics card for my setup
CPU: Intel Core i3-4160 Haswell Dual-Core 3.6GHz LGA 1150 Motherboard: GIGABYTE GA-H97-D3H LGA 1150 Intel H97 HDMI SATA 6 Gb/s RAM: HyperX Fury Black Series 8GB 240-Pin DDR3 Hard drive: Western Digital Blue WD10EZEX 1TB 7200 RPM SSD: Crucial BX100 CT250BX100SSD1 2.5" 250GB SATA 6Gbps Case: Rosewill CHALLENGER - Black Gaming ATX Mid Tower Computer Case Power Supply: Cooler Master Elite V2 - 550W L   I can only spend  200 euro on the graphics card also any help on building a PC for the first time would be appreciated  Thanks for your help
https://linustechtips.com/topic/427440-need-help-chosing-a-graphics-card/
I'd say an R9 270X or 280 on the AMD side, and on the Nvidia side a GTX 960.
i5 + r9 280/280x
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
