http://www.newegg.com/Product/Product.aspx?Item=N82E16811352049&cm_re=Fractal_r5-_-11-352-049-_-Product if I'm not mistaken, this is exactly what you want?
Edit: Oh, you just want the side panel/just the window, huh? For just the window, you should be able to just attach a plexi panel on the side panel. Otherwise, you would probably have to contact fractal directly and ask if you can get one.
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
Contact Puget systems. They sell custom cut acrylic for computers. They are also a parts dealer for fractal design in North America.
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
