CPU Voltage problem
Go to solution Solved by Jlryan,
Okay, if you say so... But I still think it happens too fast... As I said, in 10 seconds it happens like 4-5 times..
It's actually happening much faster than that, just the monitoring program can't update fast enough. Mine does it from 1.6GHz to 4.2GHz constantly swapping on all cores, unless I launch a game then it just pegs at 4.2GHz and stays there.
Hey guys ! I recently build a PC with the following specs: Rampage V Extreme, i7 5960x, SLI 980ti's etc.
I did no overclocking, I just loaded ASUS's optimized profile for the cpu. Now, at no stress (fully idle - 2%) it has like 40degrees Celsius. Ok... so i went to investigate. In CPU-Z it shows that the voltage keeps going up and down from 0.720 to 1.100, without any stress, therefore the core speed going from 1200 to 3000-ish.
Can you please help me? Thank you !
https://linustechtips.com/topic/425576-cpu-voltage-problem/
When the CPU isn't being used, it'll downvolt and downclock to save power and cooler operation
This is a signature.
https://linustechtips.com/topic/425576-cpu-voltage-problem/#findComment-5711473
Don't worry when the CPU is idle it will lower voltages and speeds
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/425576-cpu-voltage-problem/#findComment-5711501
That's fine, no need to worry about it. It's how Intel's EIST and C1E work, continuously alters the speed as an "on-demand" basis, basically background tasks will be causing it but it's normal.
Gaming/Folding rig: Coolermaster CM 690 II Advanced White | MSI Z77A-G43 | Intel Core i7 3770k @ 4.4GHz | 10GB G.Skill RAM | Nvidia GeForce GTX 780 | Samsung 840 Pro 128GB | Seagate 2TB | Seagate 2TB | WD Blue 640GB | Cogage Arrow (Passive) | Thermaltake Toughpower XT 675w | Windows 10 Pro
Photography
https://linustechtips.com/topic/425576-cpu-voltage-problem/#findComment-5711507
https://linustechtips.com/topic/425576-cpu-voltage-problem/#findComment-5711516
Photography
https://linustechtips.com/topic/425576-cpu-voltage-problem/#findComment-5711533
Truthfully it is probably happening many many more times than that. but the task manager only takes a sample once every few tenths of a second. It is absolutely fine.
Edit: This is what happens when I open 20+ interesting tabs and decide to respond too one without refreshing it.
System CPU : Ryzen 9 5950 doing whatever PBO lets it. Motherboard : Asus B550 Wifi II RAM 80GB 3600 CL 18 2x 32GB 2x 8GB GPUs Vega 56 & Tesla M40 Corsair 4000D Storage: many and varied small (512GB-1TB) SSD + 5TB WD Green PSU 1000W EVGA GOLD
You can trust me, I'm from the Internet.
https://linustechtips.com/topic/425576-cpu-voltage-problem/#findComment-5711789
