Running Two Monitors
Solved by RedSphyxis,
I tried that, it works completely fine when it's just by itself without the displayport monitor but for some reason when they're together it cant find signal.
did you check if the monitor automatically detects the signal as digital?
some monitors need to be manually shifted from analog to digital
so connect the monitor and try to figure out how to change the signal if it's not already in digital.
