Just went onto msi.com to see there were any new drivers and I found a couple for example, intel chipset, killer network, asmedia usb, etc. After updating all of that and rebooting my computer I found out that my internet is not working. I plugged the ethernet cable into my laptop and there was internet access. So it can't be the cable, it must be the new driver. I tried looking for a killer driver for win 8.1, but msi has deleted that and uploaded win 10 driver instead.
Please help, thanks.
My mobo is MSI Z97 Gaming 7.
CPU: Intel Core i7-4790K Quad-Core Processor | CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler | Motherboard: MSI Z97-GAMING 7 ATX LGA1150 Motherboard | Memory: Corsair Vengeance 16GB | Storage: Samsung 840 EVO 500GB 2.5" Solid State Drive, Seagate 4TB 3.5" 5900RPM Internal Hard Drive | Video Card: EVGA GeForce GTX 970 3.5GB ACX 2.0 Video Card x2 SLI| Case: Corsair 450D ATX Mid Tower Case | Power SupplyEVGA SuperNOVA 750 G2
https://linustechtips.com/topic/425018-msi-killer-network-problem/
http://ca.msi.com/support/mb/Z97-GAMING-7.html#down-driver&Win8.1 64
you didn't look very well
also if I were you I would trick windows into installing the basic atheros driver instead of the killer driver
the killer driver is kinda crappy
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
I followed the setup on techpower to install the atheros driver, and I dont have internet. So I also downloaded the killer driver for win 8.1 and again no internet. I am guessing at this point I will have to reinstall a new copy of windows?
On the left is in the "Win 8.1" tab and the right is in the "Win 10" tab.
check your device manager
maybe even post a screen shot of it..under network adapters
This is after I have installed the "Win 8.1" driver
your driver is installed
so thats not the problem
but I dunno what that tap 32 adapter is
uninstall it
reboot
and check if you get an ip from the router
