Check Power?
Go to solution Solved by 79 Potatoes,
At stock frequencies, an HD 5830 takes 100 W at full load and a 3570K takes 60-70 W. That's about 160 W, add 50 W for the rest, so expect 200-220 W at full load (not peaks)
Also your PSU is good, based on Seasonic.
From the wall, as it's 80+ Bronze, might draw 250 W at full load or less
TL;DR: you're fine
Well, tell us the specs and we'll tell you.
Here you go
Specs:
Intel i5 3570k
Cooler master hyper 212 evo
Msi z77a gd45
8gb G-Skill 1600 ram
Powecolor HD 5830
Antect high current 520w 80plus bronze
Samsung 840 Evo 128GB
2 1tb seagate baracuda drive
Lg cd/dvd read writer
5 120mm fans
1 200mm fan
https://linustechtips.com/topic/424932-check-power/#findComment-5703815
TL;DR: you're fine
This is a signature.
https://linustechtips.com/topic/424932-check-power/#findComment-5703845
TL;DR: you're fine
Thank you very much
https://linustechtips.com/topic/424932-check-power/#findComment-5703900
