Help on in-game lag
Go to solution Solved by Arcanekitten,
its pretty old system so there isn't that much to do about it so a gpu upgrade would be great something like a 265 or 260x
Greetings everyone, I'm new here..
help.
so here's my situation:
I play Tera, Eden Eternal, League of Legends & Warframe.
I encounter this "slightly-to-moderately annoying lag" on tera and eden eternal (w/c is not hardware Demanding) even with 30-40FPS on the lowest possible graphic settings.
whereas, in LoL (maxed graphics w/ AA) and warframe (med-high wo/ AA), I don't encounter this issue.
I'm guessing, my Hardware cant handle MMORPG's coz its getting old, or... I really have no idea.
I'm running on the ff:
OS:                                newly clean-installed windows 10
CPU:                             AMD Athlon™ II x4 635 2.9Ghz (old)
RAM:                             8Gb ddr3 1600Mghz RAM (1 old 4GB, 1 new)
Motherboard:                asrock N68C-S UCC (old)
HDD:                             Seagate 500gb (old)
GPU:                             AMD Radeon R7 250
whereas old = 3-4yrs
thanks for your time :D
https://linustechtips.com/topic/424642-help-on-in-game-lag/
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/424642-help-on-in-game-lag/#findComment-5700177
help.
oh yeah a SSD would do great things to
https://linustechtips.com/topic/424642-help-on-in-game-lag/#findComment-5700487
